polki
PC Specification: Windows 10 64 bits, GTX 1080, Intel CPU
Action! does not record Time Shift if an update is pending, failing half of the thing I want to record...
Fri May 07, 2021 5:49 am
Is there a way to auto update without asking ?
I'm starting to get mad of losing records because of Action! updates pending every few days...
Everytime I want to record via Time Shift, I press my bound hotkey and nothing works because of Action! waiting for updates to install.
Re: Action! does not record Time Shift if an update is pending, failing half of the thing I want to record...
Tue May 11, 2021 5:47 am
We cannot reproduce this problem on our end.
Could you please tell us how to do that?
polki
Wed May 12, 2021 3:06 am
Well, I have automatic update checked.
I press my keybind to record the past X minutes of gameplay, and then I check my records folder and nothing has been recorded.
I then open Action! and 100% of time that it did not record, there is a pending update.
The only fix I might have found is to disable automatic updates
