Sukomvit
PC Specification: Ryzen 5 2600 GPU 1070 windows 10 20H2
Bug Report Mic not working
Fri Jun 11, 2021 2:41 pm
Need to reinstall every time if enable or disable to separate audio file for record microphone sound just make me mad :x :x :x
Screenshot (42).png (154.1 KiB) Viewed 16495 times
Watchman
Re: Bug Report Mic not working
Fri Jun 11, 2021 8:03 pm
Hi Sukomvit,
The problem in this case might be that you have set the same USB mic device to secondary audio track and auxilary audio track.
Some devices might not work properly when 2 instances are enabled at one time. Please try to set it only on one (either secondary audio track or auxilary).
BTW, why do you want to record the same microphone sound on 2 tracks?
Thanks,
Watchman
Sukomvit
Sat Jun 12, 2021 2:07 pm
Thank you for reply
I go found answer to another post. That is my mistake is don't know video have 2 track audio and use A button to switch to listen. :oops:
Return to “General Topics”
