brazilianjoe
PC Specification: Ryzen 3600, Geforce 1660 Super, W10Pro
Low mic volume
Sun Jul 04, 2021 2:24 am
I have tested many other streaming platforms, and most of them provide a smallish range for microphone gain.
I have perused all config options on Windows, and the mic is correctly configured, but some apps just pick it at a low volume - I don't have issues on online meetings with Zoom or Google Meet for instance.
But even recording with 200% gain, if I put some e.g. background music, the mic volume is still way too low. Is it possible to increase the gain above 200%?
Re: Low mic volume
Tue Jul 06, 2021 6:05 am
Hello. Unfortunately microphone volume cannot be set at more than 200%. But open microphone settings (next to selected audio device), disable noise reduction and see if that helps.
