eran702
PC Specification: Android
monflo android
Thu Jul 08, 2021 12:39 am
hello dear devs
i have a problem
when i connect to my pc with android using wifi its going smooth and log in insta
but when i log in using my android on 4g
its getting stack on dirct connect
and if i wait.. it just going back to the connection hub
what should i do
ty
Re: monflo android
Thu Jul 08, 2021 5:42 am
Unfortunately it depends on your mobile data provider. Some of them allow such connections and some of them don't.
Shakachezwam
PC Specification: W10 i7 3060
Re: monflo android
Wed Aug 18, 2021 7:17 am
Nothing with Mobil data provider. I have the same issu but it was completely working fine during 3 months and all I have changed is my box/rooter. I let you now that even with same rules then before or when port are opened it is still not working anymore. There must be something to fix it. Sometimes I can connect and it stays or signal lost screen but I can alt f4 or any other option and it work I just can't see anything. I will be in 5g soon and I'm pretty sure the problem will keeps on...
Return to “Monflo - Remote PC Access and Gaming”
