LCartox
PC Specification: Ryzen 5 3550h, gtx 1650 mobile
When Action is running, it will crash my game when I open it.
Mon Jul 19, 2021 10:56 pm
I play a game called Geometry Dash. It is a 32 bit game. I have been using Action for a little bit, about 2 days the be specific. It was working fine, but then today, when I opened the game to play it with Action, it crashed it when it was opening. I don't know what causes this. Any help would be appreciated. I am also not going to exclude the game process, because I use the replay buffer to save space on my hard drive, and I also don't know when I am going to beat something, so having the time shift is a huge convenience, as sometimes it can take hours to do something that I only need 2 minutes of footage for a completion video.
Re: When Action is running, it will crash my game when I open it.
Tue Jul 20, 2021 5:53 am
Hello LCartox.
I have just checked the game and it is working fine on our end.
Click on, "Start Button".
Click on, "Run".
LCartox
Wed Jul 21, 2021 3:00 am
I was not able to attach a .txt file, so I did the next best thing and used pastebin
https://pastebin.com/irF3FvCr
Wed Jul 21, 2021 6:01 am
Please find the dump.reg.zip file attached below
dump.reg.zip
(488 Bytes) Downloaded 2681 times
Download it and then remove zip extension (just rename it, do not use winrar or 7zip).
Now you have dump.reg file. Double click on it to run it, click YES in UAC prompt and then again Yes to continue.
Start Action! and open the game. When it crash go to your D: drive and look for GeometryDash dmp file.
Please send it to us.
LCartox
Wed Jul 21, 2021 4:59 pm
Is there a specific file path I can find it in, or a name I can search for, because I am having a hard time finding it.
Thu Jul 22, 2021 5:43 am
The crashdump should be at D:\ without any folder.
Watchman
Tue Jul 27, 2021 1:44 pm
Hi LCartox,
Are you still having this problem? We have checked Geometry Dash and it works fine. This is an OpenGL game. Make sure to disable anything in the background that can mess with Action.
LCartox
Sun Aug 08, 2021 2:28 pm
Hi. I havent check it in a while. It is working now, but there are some inconsistencies when it comes to how the game and application start. Sometimes when I restart my computer or update graphics drivers or do something else that I dont know about, it will crash the game upon getting 1/3 of the way past the initial loading bar. I dont know what would get in the way of Action running, but any help with that would be nice.
markangelo
PC Specification: Win10
Wed Dec 18, 2024 2:40 am
I understand how frustrating that can be! Have you tried updating Action or checking for any compatibility settings? Sometimes, running the game in compatibility mode or adjusting graphics settings can help. Also, ensure your drivers are up to date. Hope you find a solution soon!
markangelo
Fri Jan 03, 2025 3:00 am
Have you tried updating Action or checking for any conflicting software? Sometimes, older versions or background applications can cause crashes. Also, make sure your graphics drivers are up to date. Good luck!
