Amrinder Singh
PC Specification: AMD A10 6800-k APU with Radeon 8780D
Missing option for AMD AMF in latest version
Sat Jul 31, 2021 6:28 am
So just as it says.
In the older version i was able to use AMD AMF to record, now i see no option. the version i am using is 4.10.1
the latest versions don't even show me that option!
Please fix this
Watchman
Re: Missing option for AMD AMF in latest version
Tue Aug 03, 2021 5:53 pm
Hi Amrinder,
What operating system and GPU setup are you using? There are workarounds in new versions as AMD stopped supporting AMF 1.0.
Update: I see that you have AMD A10 6800-k APU with Radeon 8780D. Is this a 2x GPU setup (one integrated and high performance).
You may need to enter the Power Switching options and select Action! to start on the integrated GPU (not the discrete). This might help.
