GerhartRTFO
PC Specification: i7-8700/5820/3770| gtx1070/970/680 win10
Contact: YouTube
Update 4.20.3 Arma 3 no longer recognized by Action
Tue Aug 10, 2021 2:24 pm
As of update 4.20.3 the game Arma 3 is no longer recognized by Action in "Game" mode. It still records but does not recognize the file as an Action video file. It also gives it a strange name, for example: Arma 3 _F__SteamLibrary_steamapps_common_Arma 3_Arma3_x64.exe_ -malloc=tbb4malloc_bi_x64 -hugePages -filePatching _-mod=VN;F__SteamLibrary_steamapps_common_Arma 3_!Workshop_@CBA_A3;F__SteamLibrary_steamapps_common_Arma 3_!Workshopmp4. Whereas it still gives it the correct name in "screen" mode (Arma 3 8-10-2021 02-28-46) and also still recognizes it if recorded in "screen" mode.
Basically the name it's giving the video file would be an example of a start command line for the game.
Before it's asked yes it was tested in both MP4 and AVI, neither of them worked. Actually nothing showed up for AVI but as you can see there was a file in the folder for the MP4.
Re: Update 4.20.3 Arma 3 no longer recognized by Action
Wed Aug 11, 2021 5:57 am
Action! should name recording after file description of the exe file.
Go to F:\SteamLibrary\steamapps\common\Arma 3, right click on Arma_x64.exe file and open properties.
In properties window go to "Details" tab and check what is the file description.
GerhartRTFO
Contact: YouTube
Wed Aug 11, 2021 6:24 am
File description is Arma 3. Just an FYI, an hour before I let Action update I had no issue and worked as it always did. Once the update went through then it got all buggy. I did restart my system just to make sure that wasn't the issue but no difference.
Thu Aug 12, 2021 5:45 am
This problem will be fixed with next update.
GerhartRTFO
Contact: YouTube
Thu Aug 12, 2021 11:02 am
That's great to hear, thank you very much
GerhartRTFO
Contact: YouTube
Tue Aug 24, 2021 11:34 am
Just wanted to post a sitrep. Action is back working correctly now, thank you for fixing the issue.
