TheMontyB
PC Specification: 3700X, RTX 2080 FE, 32GB RAM, W10 2009
Black Ops Cold War - odd file naming bug
Sat Aug 21, 2021 5:47 pm
Ever since the last update, I've had a weird issue where instead of the file being named:
"​C​a​l​l​ ​o​f​ ​D​u​t​y​®​_​ ​B​l​a​c​k​ ​O​p​s​ ​C​o​l​d​ ​W​a​r​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​ TimeShift xx-xx-20xx xx-xx-xx.mp4"
It's now named:
"C​a​l​l​ ​o​f​ ​D​u​t​y​®​_​ ​B​l​a​c​k​ ​O​p​s​ ​C​o​l​d​ ​W​a​r​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​" when recording manually or "C​a​l​l​ ​o​f​ ​D​u​t​y​®​_​ ​B​l​a​c​k​ ​O​p​s​ ​C​o​l​" with TimeShift. The .mp4 suffix is missing but the video works fine if added manually.
No other game seems to be affected. BFV, Call of Duty 2 both work without any issue for example.
Happens with and without having the new folder feature selected.
Here's a screenshot with the file names & how Action looks when hooked into BOCW: https://i.imgur.com/HrYSObl.png
(there was one video which saved with the day, but then ended there. I can't replicate that happening.)
I'm fully expecting this to be completely unproducible and only an issue on my setup...
Thanks.
Re: Black Ops Cold War - odd file naming bug
Tue Aug 24, 2021 1:00 pm
Hello. This issue will be fixed with next release.
