Cogweasel
PC Specification: Win10, AMD, GTX
Automatically split files into parts problem or liimtation?
Thu Aug 26, 2021 6:32 pm
I am having problems with the "Automatically split files into parts" function. The files generated don't edit together seamlessly, there is always a jump cut (MP4 NVENC 1080P). I am of course not sure if this is supposed to be this way, but is there a way to get the files to split seamlessly or is this just a limitation? If it is a limitation, would it be possible to have the files split seamless after the recording finished. I know there are tools that can do this without re-encoding, but haven't found one that work or that I dare to install :) ...
Re: Automatically split files into parts problem or liimtation?
Fri Aug 27, 2021 6:16 am
It always takes some time to finish one recording and start new encoder. There is not much that we can do.
Cogweasel
Mon Aug 30, 2021 10:00 pm
Thank you for your fast reply! I suspected as much. But would it be possible to include a function to split files seamlessly and without re-encoding, after recording has finished? I would find this rather useful...
