Hellmut
PC Specification: Intel I9 9980X; SLI RTX 2080 TI; Win 10
Action! and crackling sound
Fri Aug 27, 2021 10:47 am
Hi! I have a problem. It directly connected with your program. I checked another recording program such as Bandicam and everything is fine. With a high volume (90-100%) or when in some game sound suddenly become very loud (explosion) my audio will be full of crackling sound (overload). This is very old problem (4 months at least) but i ma tired to lower general volume to avoid this. Can you help me? Thank you.
Re: Action! and crackling sound
Tue Aug 31, 2021 10:03 am
Hello. We have similar problem on one of ours laptops. We are investigating the issue but it looks like it is a problem with audio adapter's drivers.
Hellmut
Tue Aug 31, 2021 10:43 am
Maybe but I had my audio device for a very long time. And it's very specific and audio driver did not change in years (10 - 11 years).
CrimsonB
PC Specification: Win10Pro, Intel Core i7-10750H, RTX 2060
Wed Sep 08, 2021 5:48 pm
I am having a similar issue which did not exist before. I use this program for school lectures and I am hoping this can be resolved quickly.
Hellmut
Sat Nov 20, 2021 12:45 pm
Hello. Did you figured it out? What was the problem? I can't see any changes in recent updates. I can send you a direct youtube link with this issue.
Rameyuk
PC Specification: i9-9900K, RTX 2080 Ti, Windows 11
Sat Nov 27, 2021 1:13 pm
I also have the exact same problem. Here is an example of what the crackling sound looks like.
https://youtu.be/v6g8JroRswA?t=2280
Action
Action Version: 4.23.0
Recording Resolution: Original (2160p)
Recording Mode: Live Streaming - Game & Applications
Windows and Hardware
OS: Windows 11
Video Card: Nvidia GeForce RTX 2080 Ti
Video Driver Version: 496.76
CPU brand and model: Intel Core i9 9900K
Motherboard brand and model: MSI MPG Z390I GAMING EDGE AC
Memory: 32 GB
Monitor Resolution: 3840x2160
Problem Description
Game/App Problem: Microsoft Flight Simulator (2020)
Error Type: Crackling noise
Video Editor: N/A
Description: During live broadcast and recording, Action! seems to make crackling noises in the result. It seems that it's occuring when it's trying to stream and record low-frequency sounds of jet engine spool. It reminds me of a phenomenon if you have a cheap subwoofer, and trying to play heavy bass music, and the subwoofer just couldn't make the sound so it crackles on sounds below a certain frequency.
SjD
PC Specification: ASUS H270 m/b, Rx580, i5-7400, Win 10
Sun Mar 19, 2023 6:41 pm
I have been having this problem recently also. I unstalled and reinstalled Action, and it was only after the reinstall that I had the crackling problem. Prior to this, Action worked really well. Everything else is unchanged. It may perhaps be a newer version of Action that is causing the issue?
Otherwise all good, Action has been great.
