Sascha
PC Specification: 6-Core Ryzen7, RTX 2060 Super, Win 10.
Can no longer edit Action! Recordings.
Mon Sep 13, 2021 4:50 am
Hello, I updated my action version from I think it was 4.16.x to the newest version 4.21.4 and now I am unable to edit recordings in DaVinci Resolve. They also won't play properly in windows video player or VLC. Here's what happens when I try to play/import the files, they both work in the built in Action player but mixed results elsewhere.
Resolve: .MP4 imports and plays audio, but no video. Has a "Media Offline" displayed over the video box but otherwise the audio is fine. Trying to import .AVI just results in a brief pause and nothing being imported.
VLC: Seems to play MP4 ok but .AVI has horrendous buzzing over the audio track.
Windows video player: MP4 gives some errors but plays audio. .AVI just displays unknown file format error.
Additional information:
- It was working fine before the update
- I tried updating Resolve but it didn't fix the problem
- I have "Allow multi-channel audio recording" turned OFF. I double checked because know having this on has caused me a lot of issues in the past.
- I have tried both recording my desktop and a selected application window.
- I imported some screen captures I made with a slightly older version of action and they work fine EVERYWHERE.
- Here is an example recording which I now can't edit (https://drive.google.com/open?id=10a1ga ... xtBtSKvvdb)
I wanted to reinstall the old 4.16 version to keep working but I can only find downloads for the latest version and latest updates of old major versions 3.xx.x etc. :x
Re: Can no longer edit Action! Recordings.
Mon Sep 13, 2021 9:17 am
Hello.
Your video is in a HEVC format. HEVC format was never supported in DaVinci Resolve, neither do AVI.
Sascha
Mon Sep 13, 2021 10:57 am
Hello.
Yes! That fixed it! Thank you, I've been pulling my hair out all day trying to figure out what was wrong. I don't know how or when it got changed over to HEVC
Screenshot 2021-09-13 035557.jpg (18.09 KiB) Viewed 26897 times
. Guess I just glossed over the dropdown since it looked like a string of gibberish to me.
Return to “Video editing”
