TDFCheef
PC Specification: i7-4790K, GTX 1070, Windows 10
Error 0xc150004 when launching Action
Fri Sep 24, 2021 7:18 am
Hello
For the last few days, I've had the issue of getting an error message when trying to launch Action!: "The the application was unable to start correctly (0xc0150004). click OK to close the application. Clicking OK to close the application."
Clicking OK closes the error itself, but the Program is stuck in the loading animation until i kill the task using task manager.
Reinstalling Action! has not fixed the problem, though using system restore and going back to a restore point of around a week ago did fix the problem for about 1-2 days. I have not installed any programs during this time.
I've attached the DirectX Diagnostic file
Any help would be greatly appreciated, thanks.
DxDiag.zip
(16.18 KiB) Downloaded 842 times
Re: Error 0xc150004 when launching Action
Fri Sep 24, 2021 8:33 am
It is not a problem with Action! but most likely it is a problem with missing or corrupted system file/s.
Try the steps shown here: https://windowsreport.com/application-error-0xc0150004/
and see if that works.
