jvmagni
PC Specification: i7 2600K, GTX 970, Windows 10
How to record aditional audio output
Sat Oct 16, 2021 6:17 pm
So I've setup Voicemeeter to record my discord sound separate from the game audio. It works fine with Dxtory but I purchased Action and could not find the right option to add an aditional audio source. I can only record the main audio output and mic. Is there any option to add this secondary output like in Dxtory?
Thanks!
jvmagni
How to record multiple audio outputs (in game + Comms)
Sat Oct 16, 2021 9:08 pm
I'm wondering if it's possible to configure Action multiple audio outputs channels. I have Voicemeeter configured and used to record with Dxtory. Since I bought Action I can't find an option to record this second audio source to separate my in game audio from my discord/communication audio. What should I do?
Re: How to record aditional audio output
Wed Oct 20, 2021 6:07 am
There is an option called "Enable/disable additional audio recording into separate audio file" below Secondary Sound Device.
You can also use audio recording feature in Action!
