Michelin18
PC Specification: 3600xt-5700xt-WIndows10
some help with this issue
Sat Nov 20, 2021 2:47 pm
hi how are you
i been uising the software and it works great. but here is where it gets weird. i use a mod call SK to give the HDR usually DX11 games. when I use the mod and Action. i get a crash when the game is loading or saving.
does any body here uses SK or have heard of SK to turn HDR on games. when I uses action with without the mod. the software works great,
also when I'm using SK and action I have to use the screen toggle . dx toggle doesnt turn it on in game, SK does is a .dl to do its tonemaping with HDR.
basically the mod that gives dx11 games hdr doesnt work with action and I cant record. well I can but there are a lot of crashes. i use it because is way better than windows auto HDR
if I remember correctly , some old versions use to work fine with it.
can I get access to the older version . it will be a matter of trial and error . i doubt the devs would look up SK and give some kind of support for 1 or 2 people.
thanks
