steen
PC Specification: Windows 7 - 64 bit
Auto start recording
Mon Nov 22, 2021 4:08 pm
Question 1
How can I define how long a recording should be before Action! automatically stop recording?
Question 2
How Do I Get Action! to record on a schedule when I'm not home?
Must automatically start recording and end recording
Re: Auto start recording
Tue Nov 23, 2021 6:47 am
Answer 1.
In the main tab, if you scroll down a little, you will find a "duration" option. Use it to set duration for your recordings.
Answer 2.
There is no scheduling mechanism in Action!. It is possible to do that using Task Scheduler in Windows and additional sctipts/programs.
Return to “General Topics”
