zinamole
PC Specification: window 10
Unable to record game audio & mic at once
Thu Dec 02, 2021 1:04 pm
I have my mic (Behringer C-~1) connected to Alessis io2 interface which is connected to PC via USB.
When using default configuration i hear game audio only and when changing it to my microphone i hear my mic with no game audio.
The video is fine, the problem is I have to use additional things like Audacity to record my mic. Is there any way to record both of audio layers?
Thanks in advance
Re: Unable to record game audio & mic at once
Fri Dec 03, 2021 7:58 am
Hello.
Please make sure to enable both Primary Sound Device and Secondary Sound Device options.
zinamole
Mon Dec 06, 2021 10:27 am
you are using the "Record microphone into separate audio track" feature. The "Record microphone into separate audio track" feature create a separate audio track in your video file. No additional files are created. When you play back your video file, you will hear only one audio track at a one time. Press "A" to switch between track.
