Tymorafarr
PC Specification: Windows 10, i7-6770k, nVidia GTX 980
Re: Cracking audio
Wed Feb 23, 2022 12:02 pm
It did not work unfortunately. I recorded a footage at 30% of the volume. I still could hear the cracklings. I bumped up the volume during post-processing so the cracks could be heard clearer
https://streamable.com/tbk4or
Just an additional info though, I had no audio issue with the same setup in Bandicam, OBS and Xsplit
Rameyuk
PC Specification: i9-9900K, RTX 2080 Ti, Windows 11
Re: Cracking audio
Wed May 04, 2022 5:34 pm
I also have the exact same problem. Here is an example of what the crackling sound looks like.
https://youtu.be/ibbQgmdClFU?t=1650
Action
Action Version: 4.27.1
Recording Resolution: Original (2160p)
Recording Mode: Live Streaming - Game & Applications
Windows and Hardware
OS: Windows 11
Video Card: Nvidia GeForce RTX 2080 Ti
Video Driver Version: 496.76
CPU brand and model: Intel Core i9 9900K
Motherboard brand and model: MSI MPG Z390I GAMING EDGE AC
Memory: 32 GB
Monitor Resolution: 3840x2160
Problem Description
Game/App Problem: Microsoft Flight Simulator (2020)
Error Type: Crackling noise
Video Editor: N/A
Description: During live broadcast and recording, Action! seems to make crackling noises in the result. It seems that it's occuring when it's trying to stream and record low-frequency sounds of jet engine spool. It reminds me of a phenomenon if you have a cheap subwoofer, and trying to play heavy bass music, and the subwoofer just couldn't make the sound so it crackles on sounds below a certain frequency.
Voltaic
PC Specification: AMD Ryzen 7 5800X, NvIDIA 3080, Wind 10
Re: Cracking audio
Fri Nov 11, 2022 9:14 pm
Hello!
Was this ever resolved? I am having the same issue now. I tried lowering the volume, both in the system and in Action! but it persists. Any tips are appreciated, thank you.
dfg555
PC Specification: Ryzen 9 5900X, 3090, Windows 10 v22H2
Re: Cracking audio
Sun Nov 20, 2022 4:10 am
Not sure if you guys use any type of Virtual Cables but I changed the Input Source to the Output Source (CABLE Output) instead and it fixed my problem. I'm assuming (probably wrong, someone can correct me?) it has something to do with passing audio through hardware then through a software virtual cable and then through another software virtual cable which is then being recorded which probably causes these crackling sounds as it goes through multiple stages of "compression". Whereas changing the Input Source to the Output Source instead it only goes through the hardware then through the virtual cable.
The attachment 1.png is no longer available
Voltaic
Re: Cracking audio
Mon Nov 28, 2022 10:44 pm
Thanks for the tip, however I personally don't have that option.
Screenshot 2022-11-28 175107.png (24.6 KiB) Viewed 49898 times
Voltaic
Re: Cracking audio
Sat Dec 10, 2022 1:15 am
Anyone from Action! support?! I have bought and tested an add-on sound card (Asus Xonar) and tested it as my sound output. No difference, the sound comes out crackled.
Please help!
Also; some of my previous comments here never posted
FRIST_008
PC Specification: Amd 5900x, 3080 rtx, windows 11 22h2
Re: Cracking audio
Sun Jan 01, 2023 6:10 pm
Oy, I have this problem. Always with one game.
https://youtu.be/T3FpSY_vlJc
Game - DARQ. Time code 0:53
I can work with you team for future fix.
but... since this video i have upgraded windows and processor for one generation. But this problem is very rare for me in other games. But in this game it is especially relevant.
Re: Cracking audio
Wed Jan 04, 2023 6:57 am
What option have you selected in Primary Sound Device?
FRIST_008
Re: Cracking audio
Fri Jan 06, 2023 4:38 pm
By default on windows by HDMI 2.0 from 3080 to sony bravia kd 65ag9 by eArc
