steen
PC Specification: Windows 7 - 64 bit
Split recordings after every 43 minuts recording
Sun May 08, 2022 7:51 am
Action!
Hi
When I have to record my screen for 3 hours, how can I make a setup that makes that Action! automatically saves the recordings after, for example, 43 minutes?
example.
Record saved part 1 - 43 min.
Record saved part 2 - 43 min.
Record saved part 3 - 43 min.
Record saved part 4 - 43 min.
Re: Split recordings after every 43 minuts recording
Mon May 09, 2022 7:33 am
If you go to Settings -> Video you will find the option you need.
aquareading
PC Specification: Windows 11 Pro
Thu Apr 17, 2025 1:47 am
Use Action!'s "Auto-split recording" feature and set the split duration to 43 minutes in settings. It will auto-save each part.
Return to “General Topics”
