c3ns1o
PC Specification: Ryzen 5950x - 6900xt Nitro+
Audio problem with Discord
Tue May 10, 2022 6:42 pm
Hello Guys,
i have the problem whene i record the audio from Discord, that it has noise in the livestream. A kind of crackling.
What can be the reason for this?
All other audio sources works well but Discord seems to loud or overdriven, at default settings.
Here once a livestream where it can be heard. Its ther whene a USer begin to speak. Is teh User talking longer, its stop crackling and audio will be fine.
https://youtu.be/iP5BCvJoPNY?t=9414
Operating System
  • Windows 11
Computer:
  • LC Power LC-M34-UWQHD-144-C-V2
  • MSI MEG B550 Unity-X
  • Ryzen 9 5950x
  • 32 GB DDR 4 RAM Crucial Ballistix 3200 @3900 MHz Stable
  • be quiet! Dark Power Pro 12 Netzteil 1200W
  • Samsung 980 PRO 1 TB PCIe 4.0
  • Corsair Force MP510 240 GB M.2
  • Logitech C920 Webcam
  • Behringer UMC202HD U-Phoria
  • Sapphire RX6900 XT Nitro+ 16GB
  • NVIDIA 3050
c3ns1o
Re: Audio problem with Discord
Wed May 11, 2022 12:37 pm
Good...
Today I played a bit with the volume of different users and despite the fact that it is rather unlikely and the volume of each user is identical, it was an "overdrive" of the volume, although they themselves have sounded clear and distinct. In short, the sound in the headset was normal and only overdriven in the livestream.
Solusion In short!
I went down in Discord for the individual users from 100% to 80 to 85 percent of the volume and the stream is again free of distortion of the voices.
I would have bet that it is not the volume in Discord!
So you can deceive yourself!
Problem solved!
