Zecchin
PC Specification: 4 RAM, 1 Tbyte HD, I Core 5
Video Size Record Doubt
Sat Jun 25, 2022 5:56 pm
My display screen is 1364x768. I record videos for YouTube, so a good size for record is 1920x1080. Because my display is smaller than 1080p, when I record in 1080p the quality is smaller too? If no, Is it better I record in original size (768p) and change the size in a editor or already record in 1080p? :ugeek: :?:
Re: Video Size Record Doubt
Mon Jun 27, 2022 6:04 am
No matter,if you record in 1080p or resize the video in postproduction, quality of your video won't be as good as true 1080p.
20220713
PC Specification: R7 5800X, GTX1080Ti, windows11
Sat Jul 16, 2022 10:59 am
Hi, can Action give higher bitrate limitation for 1080P30FPS streaming? Now in the streaming tab, it is limited to 6mbps for 1080P30. My screen is in 3840x2160, and cannot get higher bitrate for 1080P30 streaming. That bitrate is not enough because I stream the first persion shooting game and the view is changable, need more bitrate.
LenaClayton12
PC Specification: i3 10105F h410 gtx1650
Tue Apr 18, 2023 1:04 pm
If you plan on uploading the videos to YouTube, it's generally better to record in the higher resolution (1080p) as YouTube will compress and re-encode the video to fit its own specifications, which can result in a loss of quality. If you record in the lower resolution (768p) and then upscale it to 1080p in post-production, you may end up with a video that looks blurry or pixelated.
childhooddisloyal
PC Specification: CPU
Thu Jan 18, 2024 9:30 am
That's great. Thank you. :)
Return to “General Topics”
