Whip
PC Specification: Windows 10 64. GTX 1060. Intel i7-6700
Action does not work for No Man's Sky (NMS)
Wed Jul 06, 2022 2:50 am
I found this topic from a couple years back: viewtopic.php?t=62904
But since it is dated, I'm opening this thread. In the previous thread, it was stated that the problem was fixed and would be apply to an update soon. I don't know if that happened or not, but I would like to re-introduce the issue because it is [still?] not presently working. I have used Action for years and seen it improved with no issues, and with a wide variety of games made in Unity, Unreal, Java, independents, etc... It even works with my own hobby games I develop using Godot. But it does not work for NMS and I'd really like to be able to record gameplay. The details are simple:
1. Will not record in game mode in either full screen or borderless.
2. It will record in screen mode when game is in bordered mode. But this work-around isn't a solution.
3. Not only will it not record, but the recording indicator will not even appear.
I'm on an Alienware Laptop:
Windows 10 Home 64bit
Intel Core i7-10870H (16 CPU's)
nVidia GeForce RTX 3070 Laptop GPU
16GB Ram
Re: Action does not work for No Man's Sky (NMS)
Mon Jul 18, 2022 7:08 am
Hello.
Have you installed Action! with administrator's rights, because it is required in order to record Vulkan applications.
