Whetsit Tuya
PC Specification: Windows 10
Which Video Quality should I choose? Low, Normal, High, or Ultra?
Wed Jul 20, 2022 6:43 pm
OS: Windows 10 (64-bit) Home Premium 1920 x 1080 (64-bit) (144 Hz)
Processor: Intel® Core™ i7-9750H @ 2.60 Ghz (6 CPUs), (12M Cache, up to 4.50 GHz)
Memory: 16 GB RAM (Dual Channel)
Graphics: NVIDIA GeForce® GTX 1660 Ti (Notebook) 6 GB VRAM GDDR6
DirectX: DirectX® 12
Storage: 512 GB SDD
Sound Card: THX Spatial Audio
Video Editor: Lightworks/Avidemux
I use Force bitrate at 18.0 Mbps
Input range: 0-255 (Full)
Multicore Rendering is enabled
My recording preference is 1080p/60 fps for YouTube.
Re: Which Video Quality should I choose? Low, Normal, High, or Ultra?
Thu Jul 21, 2022 5:35 am
If you are using "Force bitrate" option then it does not matter what quality you choose.
Whetsit Tuya
Sat Jul 30, 2022 6:50 pm
Thanks
BrendanLarson
PC Specification: core i7
Mon Aug 15, 2022 3:01 am
I think if the network connection has problems, you should use 720 or 480 quality, the video will not be frozen
