Jakov93
PC Specification: Intel i7
Decrease the size of captured frame by Splash
Sat Oct 29, 2022 7:53 pm
the standard size of the captured frame by Splash is 900 KB,
I want to change it to the size that I want, for example, 250 KB
because with time, it takes large amount of storage, due to the high number of captured frames.
Thanks
Re: Decrease the size of captured frame by Splash
Thu Nov 03, 2022 7:00 am
I am afraid it is not possible.
SpecsPro
PC Specification: Intel, Radeon, Windows 10
Mon Jan 30, 2023 10:03 am
Old post, but once i capture some photos, i use photofiltre. You can download their latest version, but i recommend version 6.5.3.
:D and just open up photos there and resize them and save.
memorablereceive
PC Specification: Windows 11
Tue Nov 28, 2023 8:16 am
thank you, it woked for me too
boldeggnog
Tue Aug 27, 2024 7:45 am
You can make ideas by emailing the developer or leaving a review on the software's website. However, I do not agree with charging newbies. This could erode prospective consumers' trust and dissuade them from using Splash Player in the long run.
Ankifd
PC Specification: Win10
Tue Dec 03, 2024 1:46 am
I used the new version, but in the long run I don't know if there is any effect
wordlehintanswer
PC Specification: Windows 11 Pro
Wed Mar 26, 2025 2:21 am
I recommend checking Splash’s settings for frame compression or resolution adjustment. If unavailable, reach out to Splash support for specific commands to reduce frame size.
Return to “Splash 2.0”
