AGTDenton
PC Specification: Ryzen 9 5950x, 3080Ti TUF, W11 Pro 22H2
Action causes graphical glitches in COD Warzone II [SOLVED]
Tue Nov 22, 2022 9:28 pm
Hello
I'm having an odd problem with Call of Duty Warzone II whislt using Action.
I understand that I need to use Window mode as opposed to Game mode within Action otherwise Game mode, COD doesn't start at all.
However, whenever I have Action open in record or not, I get artifacts occuring during the game.
I uploaded an example video here:
https://rumble.com/v1vq0bg-cod-warzone- ... tches.html
At 00:14 you will see the rocks flickering
At 06:22 same again, rocks/grass flickering
At 09:44 colours go hypnotic in various places
If I don't have action open then I do not experience any of these glitches.
I wondered if you had any idea what this might be?
Many Thanks
Action
Action Version: 4.30.0
Recording Resolution: 3440 x 1440
Recording Mode: Window
Windows and Hardware
OS: Windows 11 22H2
Video Card: ASUS Tuf Geforce RTX 3080 Ti
Video Driver Version: 526.98
CPU brand and model: AMD Ryzen 9 5950x
Motherboard brand and model: MSI ACE MAX X570S
Memory: 32GB
Monitor Resolution: 3440 x 1440
Problem Description
Game/App Problem: COD Warzone II
Error Type: Corrupt Video
Video Editor: none
Description: as above
Current Versions - GeForce: 531.79 | Action: 4.31.1 | Win 11 Pro 22H2
Re: Action causes graphical glitches in COD Warzone II
Wed Nov 23, 2022 2:32 pm
Start the game first and then Action! to prevent the crashes.
That way you could record in a game mode.
We will investigate why the game is crashing in the first place.
We haven't noticed any glitches in the game, at least not those types of glitches.
Thu Nov 24, 2022 2:05 pm
Tonight there should be a new version that fixes crashing of this game.
About those glitches: could you please try lowering game resolution to 1440p and see if the issue persists.
Fri Nov 25, 2022 2:42 pm
A little late but new version is out on our website an later will be available on Steam.
Please check it out and let us know if the issue persists.
AGTDenton
Sun Dec 11, 2022 11:47 am
Thank you, I will give it another go with new version and test different resolution.
The game has had some patches as well so hopefully it will all work nicely together.
AGTDenton
Re: Action causes graphical glitches in COD Warzone II [SOLVED]
Sat Mar 04, 2023 5:41 pm
With the latest version of COD MW2 & Warzone II, Geforce Drivers (531.18) & Latest Action (4.31.0) these graphical glitches have gone. Thanks!
