Vuce
PC Specification: Windows 10, GTX 1060 6GB
Action! won't start properly
Mon Dec 26, 2022 4:29 pm
Hi
So I wanted to start Action after some time not using it, but it wont start properly.
It only shows the fps counter and some processes in the task manager. On the taskbar there is no Action icon.
I restarted the PC and tried to terminate all the Action processes, but same problem.
I already tried installing the latest Action version and the latest Nvidia drivers, but nothing seems to help.
I even tried to install Action version 3.10.2, but after starting it, only the fps counter shows too.
Do you maybe have an idea what could be the issue?
OS: Windows 10 21H2
Video Card: GTX 1060 6GB
Memory: 32GB
Monitor Resolution: 1920x1080
Re: Action! won't start properly
Tue Dec 27, 2022 9:24 am
Go to Action's location and open crash folder. Send us files that are stored there.
