ccrain24
PC Specification: intel i9, nvidia RTX 3080, windows 10
Not saving separate audio file in Action! 4
Mon Jan 02, 2023 7:08 pm
Hello, when I click to enable "record microphone into separate audio track" it does not seem to record the audio at all. The audio is not saved in the audio file and it of course is not in the video. When I do not have this selected, then the video and audio save together like normal.
Is the audio track saving somewhere different or not saving at all?
Re: Not saving separate audio file in Action! 4
Wed Jan 04, 2023 7:06 am
What you should know about "Record microphone into separated audio track" feature is that it creates an additional audio track in your video file. It does not create any additional file. While you are playing back your video file you will hear only one audio path at time. To switch between active audio track please press "A".
