TomekD
PC Specification: i7 870 @2,93 GHz | GT 240 | Windows 7
Unexplained audio distortion
Fri Jan 27, 2023 6:26 pm
I have a problem with recording system sound as the result is always slightly echoing and somewhat distorted - enough to get irritating and needing a fix. The microphone cannot be a factor as it's been unplugged. If there's a way to link an example I'd gladly do so!
Re: Unexplained audio distortion
Tue Jan 31, 2023 6:39 am
You can upload your recording using Google Drive and share the link here.
TomekD
Wed Feb 01, 2023 3:36 pm
I decided to use square waves so the difference can be easily verified - though this effect is more noticeable in most cases.
https://drive.google.com/file/d/17RZqra ... n9JRm/view - Raw file
https://drive.google.com/file/d/1da_2De ... dkeKR/view - Action recording
