AGTDenton
PC Specification: Ryzen 9 5950x, 3080Ti TUF, W11 Pro 22H2
How to improve Pixelated Twitch Stream
Sat Mar 04, 2023 6:41 pm
Hi Guys
No matter what settings I choose within Action I cannot get any Twitch stream to look unpixelated on any game.
Everyone says it's unwatchable.
When I compare my footage to my friends xBox OneX stream of the same game, his is crystal clear and he's on a far slower internet connection, so what am I missing or not doing correctly?
I have followed Twitch's guidelines but it makes absolutely no difference.
If I set my bitrate to anything above 6.000 the live stream shows only a black screen, sometimes you can hear the audio, but once the live stream ends Twitch uploads the video with the higher bitrate settings.
Many Thanks
Action
Action Version: 4.31.0
Recording Resolution: 1080p x 60fps x 6.000 bitrate
Recording Mode: Screen
Windows and Hardware
OS: Windows 11 21H2
Video Card: ASUS TUF 3080 Ti
Video Driver Version: 531.18
CPU brand and model: Ryzen 5950X
Motherboard brand and model: MSI MEG ACE MAX X570S
Memory: 64GB
Monitor Resolution: 3440x1440
Internet: 450Mbps Down / 450Mbps Up FTTP
Current Versions - GeForce: 531.79 | Action: 4.31.1 | Win 11 Pro 22H2
Re: How to improve Pixelated Twitch Stream
Tue Mar 07, 2023 6:36 am
Hello. Do you use NVidia NVENV hardware acceleration?
AGTDenton
Thu Mar 16, 2023 12:28 pm
Piotr wrote:Hello. Do you use NVidia NVENV hardware acceleration?
I have 3 NVENC options available:
nVidia NVENC
nVidia NVENC HEVC
nVidia NVENC HDR10
I have tried all 3 with no noticable difference in quality.
Do I need to configure NVENC elsewhere?
Many Thanks
nanalyly
PC Specification: 16GB
Mon Jul 14, 2025 4:38 am
The encoder compresses video and audio data for streaming, and Twitch caps bitrate at 6,000–8,000 Kbps for H.264 encoding, which limits quality at higher resolutions like 1080p60.
RubyJackson
PC Specification: Intel Core i5-11400F
Fri Jul 25, 2025 4:51 am
Twitch hard limits live ingest at ~6000 kbps for non-partnered streamers. Going over can cause black screens.
elonmakmalon
PC Specification: Windows 10
Fri Oct 31, 2025 7:49 am
Even though your hardware is more than capable, Twitch’s compression for non-partnered streamers (around 6,000 Kbps) just can’t handle high-motion gameplay very well.
