johnm
PC Specification: windows 10
GUI Doesn't Launch
Wed Apr 05, 2023 5:44 pm
Hi All,
This problem comes and goes for me but this most recent occurrence has lasted several days now and persists through restarts/shutdowns.
The issue is that GUI does not display. It is not minimized, it just never launches. Screen recording still works via hotkey.
I have tried the following:
1. Windows Updates
2. Graphics Card Updates
3. Most recent version of Action installed (4.31.1)
4. right clicked windows task bar to cascade windows
5. alt+tab through windows then windows key left/right to snap window (this never worked with action in general, however)
Thanks in advance.
Re: GUI Doesn't Launch
Thu Apr 06, 2023 5:39 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
