Rafal
PC Specification: Windows 10
Default settings for Action!
Fri May 05, 2023 4:07 pm
Hi
How to restore the factory (default) settings for Action!
Re: Default settings for Action!
Tue Jun 20, 2023 5:36 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
