PV28638
PC Specification: Win 11 Home, CPU i7
Request: Hide/Show Cursor using HotKey, for use with ZoomIt S/W
Mon May 08, 2023 2:14 pm
Hello!
I was searching for a Zoom-In/Out functionality during recording in Action 4 and I can't find any option.
• Does anyone have any solution for such Zoom-In/Out ability during recording using Action 4?
From my research on workarounds, I found the ZoomIt software (from SysInternals/Microsoft) where I can set a HotKey (i.e. Ctrl+Shift+2) to enable or disable LiveZoom.
This works great, but I noticed that when I am recording and I am entering in LiveZoom mode Action records 2 cursors, moving with different speeds, which is really annoying! (Search the text "How To Fix OBS Studio and ZoomIt for Screencasts (Double Cursor Bug)" in Youtube to understand the issue faced on other S/W too)
To my understanding,
A) Either Action 4 should implement a LiveZoom function as ZoomIt, or
B) Just provide an Extra Customizable HotKey to enable/disable cursor view during recording.
The solution B seems much faster and easier, and the idea behind it is to have the same HotKey to disable/enable the Mouse Cursor in Action4, with the same ZoomIt hotkey which enables/disables the LiveZoom.
Thus, could this be implemented (soon)?
Thanks
