chase3
PC Specification: CPU
Mirillis Splash Player Pro v2.0
Sat Jun 24, 2023 9:42 am
Okay so i have been deeply in love with Mirillis Splash Player Pro. So much that i won't watch a movie without it. Setting the advanced Picture options to Motion, Detail and Light Boost ... it's a pleasure to watch a movie in all 60fps glory.
However, i have noticed a problem and it's been there since the original Splash Pro Ex version. Large Size files (such as Original BluRays etc) always seem to have a jerky playback (when using the Motion Boost). It's as if, the software is having difficulty in keeping up and processing the huge amount of data.
For example, if running a 10GB+ File, it'd run perfectly fine IF the resolution is 720p. But will start to jerk if same file size is 1080p. MY PC is perfectly capable of running all high end video games at max settings (or closer) so i don't think the PC is the real issue here.
Anyone else having the same issue?
convertdocument
PC Specification: i7
Re: Mirillis Splash Player Pro v2.0
Mon Nov 04, 2024 9:23 am
It sounds like your issue with jerky playback on large files while using Motion Boost in Mirillis Splash Player Pro could be related to how the software processes high-resolution content. You may want to check for any updates or optimizations within the player or consider adjusting the playback settings to see if that improves performance.
convertdocument
Tue Nov 05, 2024 9:43 am
It sounds like your PC's performance may not be optimized for handling high-bitrate 1080p content with Motion Boost enabled in Mirillis Splash Player Pro. You might want to check for software updates, or adjust your settings to see if that improves playback.
PhyllisBarlow
PC Specification: Windows 11
Wed Nov 27, 2024 4:35 am
Motion Boost relies on your CPU and GPU to process and upscale video, especially with higher resolutions like 1080p. Even if your PC is powerful, the software might not be fully utilizing your system’s resources, especially if the Motion Boost effect is too demanding on the hardware for large files. If the system isn't keeping up with the processing demands, it could lead to jerky or stuttery playback.
Linamilton
Mon Dec 16, 2024 7:15 am
Since your PC can handle high-end games, it might be a software or settings optimization issue rather than hardware. Maybe try adjusting the Motion Boost or Light Boost settings, or check for software updates that might address this issue. Anyone else experiencing similar issues with high-res files?
lacrosseretouch
PC Specification: CPU model
Thu Feb 06, 2025 3:33 am
It sounds like you're having an issue with the Motion Boost feature in Mirillis Splash Player Pro, especially when playing large 1080p files, which is quite frustrating given how much you enjoy the software.
Given that your PC is capable of running high-end video games without issues, it’s likely not the hardware.
arkcharity
Tue Feb 11, 2025 11:03 am
Do you have any recommendations on what settings to adjust first?
zarvaude
PC Specification: 11
Wed Feb 12, 2025 2:14 am
Sometimes switching between DXVA and software decoding can make a difference. Would love to hear if anyone else has found a solid fix for this!
genoamemory
PC Specification: Intel Core i7-12700K
Fri May 16, 2025 9:44 am
Your PC’s gaming performance ≠ video processing performance. Motion Boost is essentially real-time AI frame generation, which is far more taxing than gaming.
sarausa
Sat May 31, 2025 2:27 am
You're not alone in having this issue with Mirillis Splash Player Pro — it's a fairly common occurrence for some users when enabling Advanced Picture features like Motion², Detail Boost, and Light Boost, especially when watching very high bitrate video files like native Blu-rays.
Return to “Splash 2.0”
