Drahy
PC Specification: Windows 10, RTX 2070 Super
Color HDR problems on Windows 11
Sun Jul 16, 2023 4:37 pm
I am using Windows 11 + Mirillis action 4.35.0. I have strange color recordings now. Not sure what caused it. It was working before somehow.
How it should look like:
The attachment Splash_WdPz5ziKt5_0.jpg is no longer available
How it looks now:
The attachment Action_UvcZh5soJh_11.jpg is no longer available
I have not changed anything except drivers and general updates. I tried changing Input Range on both Vnidia Control panel and Mirillis settings. No change. When I have not active screen (meaning recoding game in background) it works ok - any idea how to fix it?
Thank you all!
Re: Color HDR problems on Windows 11
Tue Jul 18, 2023 5:40 am
Try disabling HDR in Windows display settings and see if that helps.
Drahy
Tue Jul 18, 2023 9:58 am
This is the recorded image - it somwhow errored during upload process - by disabling HDR I cannot use it ingame I want this resulkt to be the same.
It seems only Fullscreen does that - When I choose Fullscreen Windowed it is recorded ok (like in the first picture)
Can you fix this also for the fullscreen please?
Thank you!
Wed Jul 19, 2023 5:36 am
Either Windows update or new graphics drivers caused this problem. We will try to recreate this issue.
