Skeechey
PC Specification: Ryzen 7 5700x, RTX 3060 VISION OC 12GB
How to record csgo in 1280x960 (4:3)
Mon Sep 11, 2023 3:43 pm
Whenever i try to record my game i have blackbars and there is not tutorial how to make it, also i tried to configure it in the settings but i cannot seem to find the correct settings for this.
Thank you for you help.
richardshortt
PC Specification: Windows 10
Re: How to record csgo in 1280x960 (4:3)
Thu May 02, 2024 10:26 am
To record CS:GO in 1280x960 (4:3) resolution using Mirillis software, you can follow these steps:
1. Go to the settings or preferences menu of the software. Look for the video or recording settings.
2. In the video settings, you should find options related to resolution and aspect ratio. Look for an option to set the resolution manually or customize it.
3. Set the resolution to 1280x960. Make sure you choose the 4:3 aspect ratio.
4. Save the settings and exit the preferences or settings menu.
5. Start recording your CS:GO gameplay using Mirillis software.
By setting the resolution to 1280x960 and ensuring the 4:3 aspect ratio, you should be able to record CS:GO without black bars. If you still encounter black bars, there might be additional settings or configurations within the software that you need to adjust.
oductpester
PC Specification: Window 10
Tue May 07, 2024 7:25 am
I just tried changing the resolution to 1280x960 and the aspect ratio to 4:3 like you said but the black bar doesn't disappear. :( Is there any other way to fix this problem?
enchantedjobless
Wed Jun 19, 2024 7:32 am
Can you determine what version of the game is compatible with your configuration? The error may be coming from memory.
hatevengeful
PC Specification: AMD Ryzen 9 7900X
Tue Aug 27, 2024 2:36 pm
Set your in-game resolution to 1280x960 with an aspect ratio of 4:3. To avoid black bars, you need to change the scaling mode to "Full-screen" or "Stretched" in your graphics settings. This will stretch the game to fit your screen.
mikehalloween
PC Specification: Windows 10 Home
Fri Aug 01, 2025 1:50 am
Thanks for the clear instructions on recording CS:GO at 1280x960!
robbersworship
PC Specification: Windows 11
Wed Aug 06, 2025 4:35 pm
Set your game resolution to 1280x960 with a 4:3 aspect ratio. To eliminate black bars on the sides, make sure to adjust your scaling mode in the graphics settings to "Full-screen" or "Stretched". This will stretch the image to fill your entire display.
universalkelp
Wed Sep 03, 2025 7:35 am
You need to set your game resolution to match the recording aspect ratio (e.g., 16:9, 1920x1080) or enable “Stretch/Scale to Fit” in your recording software to remove black bars.
beanjump
PC Specification: CPU model
Mon Oct 06, 2025 3:30 am
Black bars appear because the recording resolution or aspect ratio doesn’t match your game’s; set your capture resolution to the same as your game (e.g. 1920x1080) to fix it.
olivesleepys
Mon Nov 03, 2025 3:50 am
Hey! Recording CS:GO in 4:3 can be tricky. Ensure your recording software (OBS, etc.) is set to 1280x960 resolution and your aspect ratio matches. Some scaling options might cause black bars – experiment with "stretch to fit screen."
Return to “General Topics”
