BSG_PGNC
PC Specification: FX8350, XFX Radeon 5500XT, W10 Pro
Capture Card Compatibility
Thu Oct 05, 2023 5:13 am
I purchased the EVGA Capture XR1 Pro and it's grey out in the drop-down, this is one of the best capture devices on the market.
And just wondering if you are going to make it compatible in future updates.
Also using the USB Capture Feature on the PS Vita is also the same way, it shows in the drop-down for capture devices, but also greyed out and doesn't work!
Works with Xsplit and OBS, but not with Mirillis, and honestly, I like the quality of Mirillis software more, and works better with my VTuber streams.
Please Let me know if you have any plans on fixing this in the future and allowing it to use these devices.
Screenshot (37).png (56.22 KiB) Viewed 163228 times
