DERSPAWN
PC Specification: i7-11700F, Rtx 3060,win 10
Stuttery Recording When Using Nvidia
Sun Oct 22, 2023 4:04 pm
so recently ive been getting stuttery recordings when using nvidia container when recording. I'm not too sure if its because of the last nvidia drivers update or the last action update, all the new recordings are choppy both video and audio, and weirdly shaky like when v-sync is extremely bad. I reinstalled both using software that removes all remaining files and it's the same thing. so something is conflicting.
Ps. its fine if I disable it but the frames are cut by too much to enjoy recording with it. and yes I tested it with GPU scheduling too.
Re: Stuttery Recording When Using Nvidia
Tue Oct 24, 2023 5:41 am
Hello. What do you mean by "using nvidia container"? Could you please describe your setup so we could try to recreate this issue?
DERSPAWN
Fri Oct 27, 2023 4:06 pm
its like a off vsync. this video may show you a bit but its worst than that. its too bad to upload to be honest. it seems like uploading it to youtube fixes it slightly. it only happens when I use the nvidia / mp4 format. worked good all the time just started on the recent update. the thing is both nvidia nd Mirillis had an update at similar date so I'm not sure which one is making this happen.
https://youtu.be/RPSnCIFVBnI?si=2ZOTehO7HRxH7f_q&t=125
jch00lig4n
PC Specification: i5-12000KF, Nvidia RTX3060ti, Windows 11
Sun Oct 29, 2023 5:45 pm
I'm having the same issue! It just started yesterday. Other recordings were fine until I installed the latest Nvidia driver. I'm thinking that is the issue. My recording is choppy and super jittery.
Björnen
PC Specification: RTX 3080 I9 11900k 64G DDR4
After latest update 4.38.0, stutters with MP4 output
Sun Oct 29, 2023 7:10 pm
Hey, so this really sucks, was recording hundreds of hours of a game and all seems to be going great, didn't bother to check the last 30 hours of recording until now, after i installed the update on the 25th.
So the problem is that it stutters, when i move around and in cutscenes, its stutters whenever there is movement with the mouse or in game cutscenes, it is unusable, so now i have to replay 30 hours, but enough of me crying.
So i tried alot of stuff and i was hoping someone had a solution for this.
- Problems started after latest update
- It works with other recording softwares
- Same problem on all 3 screens
- I can record 1080p and 2160p with no issue, it is only the 1440p wich i want to record in and have been doing
- Game capture and screen capture is the same issue
- If i record a certain area (almost entire screen) there is no issue
- The output is MP4 i want to have, it works with AVI except i get a really loud sharp sound recorded at the same time, i dont know what that is
- Doesn't matter wich codec or hardware acceleration, still the same issue
- Doesn't matter if i change from fullscreen to borderless in the game
- The game is Cyberpunk 2077
- I have RTX 3080, I9 11900k, 64G DDR4, 2K 144Hz monitors
- Video Size in Action! 1440p
- Video framerate 60fps
I have about 2-300 hours without an issue except after last update
For now i'll record in 2160p but it is not really optimal for the framerate
Any suggestions?
andressergio
PC Specification: I5960X+32GB DDR4+SLI GTX980Ti+W10x64
Tue Oct 31, 2023 12:46 am
I updated to latest NVIDIA 545.92 Drivers and also ACTION Prompted a New Update so i did it, some hours later i went to record my games as always and they are horrible choppy, tried all and the only one that works perfect is .AVI, all the rest present the same exact issue. I did a DDU to complete removal of them, installed again and same, tried the previous version i was on and same...I did have this issue in other ACTION versions and was fixed with ACTION Updates.
So i can only record in .AVI that takes like 5 times more than MP4 :/
oabeljoga
PC Specification: i7 8700K, GTX 1060 6 GB . WIN 10 PRO
Tue Oct 31, 2023 5:25 am
I have the same issue, this happens because the driver 545.92-desktop-win10-win11-64bit-international-dch-whql , i reinstalled the old driver and then everthing works fina again. Maybe mirillis have to update something this is a new driver.
Tue Oct 31, 2023 6:54 am
It is a problem with new NVIDIA drivers. We are going to release new version soon with a temp fix, but the problem should be fixed by NVIDIA.
andressergio
Tue Oct 31, 2023 8:04 pm
thank you hope you do a hotfix, i have to record on .avi and it's killing me, either way NVIDIA don't even mention that as far as i can see....
andressergio
Wed Nov 01, 2023 2:52 am
Solved today with your Update Thank You!
Just in case i didn't install New NVIDIA DRIVERS for COD 546.01 as it all working nice, have you tried them or it will again ruin ACTION?
