ReaperPlayz
PC Specification: CPU: I5-2600 GPU: GT 710 OS: Windows 10
ROBLOX Not detected as a `Game`
Thu Nov 02, 2023 10:58 am
Hello, I been trying multiple times to record roblox using the Game Capture software.
I am currently using the `ROBLOX Player` to play ROBLOX. Before, Action! use to capture the game properly and worked fine but I am starting to experience this issue for some reason. Whenever, I try click game capture at the bottom it says: Select an Application to Record (DirectX/OpenGL/Vulkan), Any reason for this? I tried reinstalling Action! and ROBLOX multiple times but doesn't work. I also tried on different recording softwares and find out that it works on different softwares but not Action! for some reason.
ReaperPlayz
Re: ROBLOX Not detected as a `Game`
Sun Nov 05, 2023 10:35 am
Is there any solutions to this?
Tue Nov 07, 2023 6:54 am
Not sure why it is not working for you. I can record roblox with no problem on my end. Have you tried recording using Screen recording mode?
ReaperPlayz
Wed Nov 08, 2023 5:14 pm
Hi! Screen recording mode work and captures my whole screen but I just want to capture ROBLOX, Is there any solutions?
Thu Nov 09, 2023 6:51 am
You can use Area recording or Window recording mode to record speciffic window or area of the screen.
ReaperPlayz
Sun Nov 12, 2023 12:56 pm
The area screen recording mode is very annoying to use and I don't like it as much, I feel like this a Milris Action Issue as ROBLOX has a new anti cheat system and it may falsely detect Action! as a exploit device and it could lead to it not working, If you can you should try to contact ROBLOX as many other users have countered the same issue.
