Whetsit Tuya
PC Specification: Windows 10
Action does not work with Ion Fury for Steam
Sat Nov 04, 2023 8:19 pm
It does not let me take sceenshots or use timeshift when it's at game mode
when it's at screen or window mode it uses integrated graphics instead of dedicated
my questions —
1. does ion fury work with action? it uses the build engine which is from the 90s
2. i need for screen and/or window mode to use my dedicated graphics card instead of integrated
i cannot use screen/window mode with integrated graphics because it has a bad framerate
Re: Action does not work with Ion Fury for Steam
Tue Nov 07, 2023 7:02 am
Start the game and open Action!. Now open command prompt as an administrator and type these two commands:
tasklist /m action_x64.dll
tasklist /m action_x86.dll
Send us results of both those commads.
Also, why do you think Action! uses integrated graphics card in Screen mode? Hardware acceleration dictates which graphics card will be used to encode video.
Whetsit Tuya
Tue Nov 07, 2023 5:24 pm
Microsoft Windows [Version 10.0.19045.3570]
(c) Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>tasklist /m action_x64.dll
Image Name PID Modules
dwm.exe 1508 action_x64.dll
lghub_system_tray.exe 13596 action_x64.dll
lghub_agent.exe 13132 action_x64.dll
NordVPN.exe 9552 action_x64.dll
FxSound.exe 15076 action_x64.dll
TranslucentTB.exe 17380 action_x64.dll
taskhostw.exe 10612 action_x64.dll
fury.exe 28072 action_x64.dll
Action_x64.bin 19424 action_x64.dll
C:\WINDOWS\system32>tasklist /m action_x86.dll
INFO: No tasks are running which match the specified criteria.
could dedicated graphics be used for screen / window?
Wed Nov 08, 2023 6:41 am
Your desktop is rendered using integrated GPU, that is why Action! shows this GPU at the bottom bar. But it doesn't mean this GPU is used for encoding.
About the game, I can see that action_x64.dll is loaded in fury.exe, which is, I'm guessing, the process of the Ion Fury. So there must be something with the way the game is rendered.
Whetsit Tuya
Wed Nov 08, 2023 7:37 pm
it works now, it looked like it may have had a low framerate because i had 4 gigabytes of storage on my ssd, when i uninstalled detroit become human my framerate looks like it was modified to 60 fps at screen mode, i couldn't use game mode with other 90s titles like fallout
mikasa
PC Specification: Wins 11
Thu Mar 21, 2024 9:38 am
I advise running Ion Fury in windowed or borderless windowed mode which allows Action! to capture the game accurately without relying on game capture mode.
Whetsit Tuya
Tue Mar 26, 2024 10:57 pm
thanks it works
geometrylitegame
Mon Aug 11, 2025 7:34 am
Ion Fury can work with Action! in Game Mode, but you may need a DirectX wrapper for compatibility.
Frowly
PC Specification: Windows 10 Pro
Thu Sep 18, 2025 9:08 am
Can Ion Fury run smoothly with Action! in Game Mode using a DirectX wrapper?
