GriffinCollier
PC Specification: Windows 10
Action! error and I need help
Mon Nov 20, 2023 9:06 am
Recently, I couldn't start the program, the screen went black for a few seconds. Then my computer froze and the system crashed immediately.
Does anyone know what this error is and how to fix it?
Re: Action! error and I need help
Tue Nov 21, 2023 6:42 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
