Phenom
PC Specification: AMD 7950X3d, RTX 4090. Windows 11
Time-Shift Webcam and Gameplay 2 sperate files
Sun Dec 24, 2023 1:28 pm
Hi, is it possible to record active WEBCAMS with the TIME SHIFT function.
Example:
I start a game and have the Time Shift function active. As soon as I press the Time Shift shortcut, should the gameplay of the last 60 seconds and separately the last 60 seconds of the webcam be saved as 1 file each?
Is there a feature here or future updates?
Greetings
Re: Time-Shift Webcam and Gameplay 2 sperate files
Tue Jan 02, 2024 7:09 am
Unfortunately webcam cannot be saved in separate file using Time-Shift function.
