AngeliusMefyrx
PC Specification: Not your concern
Removing Action! from startup process
Mon Dec 25, 2023 7:27 am
Hi
So, one thing i have noticed is that Action! is launching a process when i boot my computer even though it is not located in the startup nor from what i can tell, the services. I do not like this behavior...
How do i tell Action! not to run its background process when i boot my computer
So far, i've been renaming the .exe file...that does the job but i'd be curious to know how it is able to do so and thus cancel this from the root...
A software that is used on occasion should never run anything on one's computer until the person actually loads the software...
Thanks
Re: Removing Action! from startup process
Tue Jan 02, 2024 7:09 am
Hello.
It is a service that is only used to start Action! with administrator rights without the UAC showing up.
If you wish to disable running this service open Task Scheduler, then find and disable ActionLauncher task.
EmmaAlva
PC Specification: Window 10
Thu Jun 18, 2026 6:25 am
It sounds like Action! might be using a scheduled task or a hidden registry entry to launch its background process on startup.
