KoolBreeze420
PC Specification: Windows 10 Geforece gtx 750 Ti Intel I5
Action wont save my settings
Sat Dec 30, 2023 2:09 pm
So I can't install it on another drive. I need to have the recordings go to my mechanical drive but it always defaults to the main drive. I have to set these settings up every time I run the software and do a recording. Is this normal or is something else going on?
Any tips or knowledge you could share with me on this would be greatly appreciated.
Thank-you
KoolBreeze420
Re: Action wont save my settings
Tue Jan 02, 2024 7:06 am
Does the drive you use to save videos is internal or external?
shanreto
PC Specification: Ryzen 7800x3D, RX 7900XTX, Win10 22H2
Tue May 07, 2024 7:09 am
I'm using an internal drive. A similar incident occurred. I have to configure these options every time I start the app.
molarar
PC Specification: Windows 11
Tue Jun 04, 2024 11:24 am
Same issue! I'm saving videos on the internal.
Return to “General Topics”
