Molda22
PC Specification: Intel Xeon 1231v3, GTX 970, WIN 10 64b
Cannot make screenshots while recording
Fri Feb 23, 2024 1:12 pm
i am not sure if its mirillis issue, specific game issue or what could be causing it but:
I cannot make screenshots from FIFA (EA FC 24) while recording. No matter the settings in the game or in mirillis action, nothing helps. If i want to make screenshot, action will only make screenshot of the desktop, not the game. Game capture doesnt work at all in this game, you cannot use it, the UI wont show up, keybinds doesnt work. Only way to record the game is with screen capture, but then i cannot make screenshots as described above.
The only way i was able to take screenshot from this game was with having action open, but NOT recording. Then it will create screenshot. But if you are recording, the screenshot will only capture desktop.
This is only happening with this specific game.
I have tried setting the game as borderless windowed, fulscreen, i tried every possible setting. Nothing works.
Any ideas how to fix it? thanks
hugshoddy
PC Specification: 11SC001MVA
Re: Cannot make screenshots while recording
Tue Oct 08, 2024 7:00 am
- In Action!, make sure DirectX/OpenGL/Vulkan is enabled in the Game Capture Settings. Some games, like FIFA, may run in a specific mode (e.g., DirectX 12) that Action! struggles with.
- Alternatively, try disabling this option to see if it resolves the issue.
Users browsing this forum: No registered users and 43 guests
