Irinayf
PC Specification: windows 7
How to change my password mirillis.com ??
Mon Mar 04, 2024 8:37 am
How do I change my password?
What am I doing wrong?
Please tell me.
Thank you.
anxiouscarpus
PC Specification: CPU model
Re: How to change my password mirillis.com ??
Wed Apr 24, 2024 4:11 am
Profile => Edit account seting
trulylesson
Fri May 03, 2024 4:36 am
Click on the profile section in the right corner of the screen, then select Edit account setting.
houndstooths
PC Specification: Windows
Thu Jul 11, 2024 4:31 am
You can change your password in your personal settings, but before that you need to activate your account.
lossstarry
PC Specification: window 11
Fri Jul 12, 2024 4:15 am
Please tell me.
Thank you.
Just go to your profile and set up your account. Maybe you saved the wrong password
venomousgorilla
PC Specification: Windows 10
Mon Jul 22, 2024 8:36 am
Click on the "Login" button usually located at the top right corner of the website.
Enter your email and current password to log in.
Once logged in, look for an "Account" or "Profile" section. This is typically found in a dropdown menu under your username or profile icon.
In the account settings, look for an option like "Change Password," "Security Settings," or similar.
Click on the "Change Password" option.
You will likely need to enter your current password and then the new password you wish to set.
Confirm the new password by entering it again.
After entering the new password, look for a "Save" or "Submit" button to confirm the change.
admiredspirit
PC Specification: Windows 10 Pro, Version 21H1
Tue Jul 30, 2024 2:53 am
Click on the "Log In" button, usually located at the top right corner of the homepage. After logging in, navigate to your account settings. This might be under a dropdown menu near your profile picture or username. Look for an option that says "Change Password" or "Password Settings." Click on it.You will typically be asked to enter your current password and then the new password you want to set. Make sure your new password meets any specified criteria (such as length or complexity). Confirm the new password and save the changes.
Return to “General Topics”
