sourcocky
Cannot Upload Video
Wed Apr 24, 2024 8:25 am
Whenever I make a video, I try to upload my video to Youtube but it says "Connection with Remote Server failed". Will there be any fix for this?
Re: Cannot Upload Video
Thu Apr 25, 2024 5:36 am
Try to log in to your Youtube account again and see if that helps.
ofionk
PC Specification: Ryzen 7800x3D, RX 7900XTX, Win10 22H2
Mon Sep 16, 2024 2:50 am
Hi I am having the same issue. I tried logging back into my Youtube account but it didn't solve the issue.
charliebrown33
Mon Sep 23, 2024 7:10 am
The "Connection with Remote Server failed" error on YouTube might be due to unstable internet connectivity or server issues. Try checking your network connection, restarting your device, or uploading the video at a later time when the servers may be more stable.
irritatefishing
PC Specification: CPU model
Tue Oct 01, 2024 2:39 am
I think it's your account. You should change your account if it works for you. Also you should connect to fixed wifi or register for 4G network
eddienel10
Wed Oct 09, 2024 6:59 am
You can try checking your internet connection or resetting your router, as a weak connection can cause upload issues. If the problem persists, ensure that your software and drivers are up to date or try uploading from a different browser or device.
DougJimenez
PC Specification: Windows 10
Wed Dec 18, 2024 12:53 pm
Ensure your internet connection is stable. If you're on Wi-Fi, try switching to a wired connection or move closer to the router. Try running a speed test to see if your connection is fast enough for uploading videos.
Neselleept
PC Specification: Windows 10 Pro 64-bit
Wed Jun 04, 2025 6:34 am
I'm having the same issue, so this thread came at the perfect time. Thanks for sharing your thoughts and experience. I’ll give it a try and see if it works!
stella73
Tue Jun 24, 2025 11:30 am
I’ve had that happen too — sometimes it’s just a glitch with the upload server or internet connection. Maybe try restarting your router or uploading from a different device? Hope it gets fixed soon!
Augh1975
PC Specification: Window 11
Thu Aug 07, 2025 7:19 am
Sounds like a network issue. Are you using desktop YouTube Studio or a third-party app? Restarting your router sometimes helps too.
Return to “General Topics”
