shysterupbeat
problem with audio
Thu Apr 25, 2024 7:17 am
The audio recorded cannot be played.
Re: problem with audio
Fri Apr 26, 2024 5:36 am
could you please provide me a video sample where your issue occurs? Please upload your original video file to one of the popular sharing sites like Google Drive or Dropbox. It will help us investigate your issue.
pleburnished
Fri Sep 06, 2024 1:24 am
If you're encountering an issue where the recorded audio cannot be played, here are some troubleshooting steps to try:
1. Check File Format: Ensure the audio file is in a playable format (e.g., MP3, WAV, or AAC). Some devices or software may not support certain formats.
2. Use a Different Media Player: Try playing the audio in another media player (like VLC or a different app). The default player might have compatibility issues.
3. Corrupted File: The audio file may be corrupted. Try recording a new file to see if the issue persists.
4. Check Volume and Playback Settings: Ensure your device's sound is on, and the volume is up. Also, make sure the correct output device is selected.
5. Browser Issues (If Web-based): If you're recording or playing audio via a browser, clear the cache or try a different browser.
6. Update Audio Drivers/Software: Ensure that your audio drivers or the recording software you’re using is up to date.
If none of these steps work, let me know, and we can further diagnose the problem.
lanceparks
PC Specification: 11
Mon Oct 07, 2024 3:08 am
Thanks, it helps me
litteremerald
PC Specification: Intel Core i7-12700K
Tue Oct 15, 2024 2:38 am
Can you be more specific? :roll:
oraclesturdy
Tue Nov 05, 2024 8:25 am
Electronic devices are really hard to be faultless. Quite unfortunate. Thanks for sharing your problem. Perhaps you should share details about the product line you are using.
existchile
PC Specification: Windows 11
Tue Nov 26, 2024 3:54 am
Ensure the audio file format is compatible with your player. If the issue persists, try converting it or checking for corruption in the recording.
Return to “General Topics”
