Miserable_gamer
PC Specification: Nvidia
Please select application, game not detected
Sat Apr 27, 2024 7:55 am
Hello, I play MW2 in Window mode, I want to use time shift for instant reply moments, unfortunately instant reply can only be used in GAME mode, the game only gets detected when I launch ACTION! first then the game, but if I go onto another programme/software it doesn’t detect the game anymore, any idea why? Thanks
richardshortt
PC Specification: Windows 10
Re: Please select application, game not detected
Sun May 19, 2024 3:59 pm
Hello, I think the issue you're experiencing, where the game is not detected by Action! when you switch to another program or software, could be related to how Action! interacts with the game and the focus of the window.
Once the game is running and being captured by Action!, try switching to the other program or software you want to use. Keep the game running in the background. Go back to Action! and check if it can still capture the gameplay. If it doesn't, you can try clicking on the game window or using Alt+Tab to switch between windows and ensure that the game window remains in focus.
acidicporpoise
Tue Jul 16, 2024 2:28 am
Really hard. Each game has its own setup. Each mode is different to ensure players have better access to their own gameplay.
asciblewham
Thu Jul 25, 2024 3:35 am
To keep the game running in the background when you enter another program, you need to set permissions for the game in the settings. Please try to check because it seems that not all devices can set up this launcher.
markjackson
PC Specification: Windows 2016
Mon Jul 14, 2025 7:12 am
It sounds like you're having a frustrating experience! The issue with game detection in ACTION! might be related to how the software hooks into the game's processes. Make sure that both ACTION! and MW2 are running with the same permissions (e.g., both as administrator). Additionally, check if there are any settings in ACTION! that allow it to run in the background or maintain detection when switching between applications.
Pribits
PC Specification: cpu
Fri Sep 05, 2025 2:47 am
I also had the same problem when playing in windowed mode.
