richardshortt
PC Specification: Windows 10
Exporting in Mirillis Action
Thu May 02, 2024 10:24 am
Hi guys,
I have been recording videos in Mirillis Action! for a little more than month using a pretty basic Logitech USB headset with mic with no problems (other than it doesnt sound so great)
Following some advice I went ahead and upgraded to HyperX cloud which uses the two jacks, one for headset and one for mic. While recording in Action, I have no problem viewing and listening to the recording in the built in splash player that opens up from within the recording software.
The problem begins when I export the video to prepare it for upload to youtube. The video portion exports fine but there is no audio. I thought maybe I had messed up some settings but when I use my other headset, record and the export...the audio is just fine.
Anyone have any experience with this problem?
Re: Exporting in Mirillis Action
Tue May 07, 2024 6:40 am
Could you please send us a video sample where this issue occur. Please upload original recording using file sharing service like Dropbox or Google Drive.
richardshortt
Sun May 12, 2024 9:08 pm
I changed the Audio Device to my new mic in the Audio settings tab and then the problem solved. Anyway, thanks for your answer..
evokerbuzz
PC Specification: Windows 11
Tue Jul 23, 2024 6:58 am
Quick fix. Great experience!
unawarecybs
PC Specification: CPU model
Sat Nov 08, 2025 3:09 am
Hey! Facing the same audio issue with dual-jack headsets sometimes. Mirillis Action! might not be detecting the HyperX mic properly during export. Try checking your audio input settings in Action! specifically for the export profile. Also, ensure the mic is set as the default recording device in Windows sound settings. Could be a driver conflict too.
