hakanayas
PC Specification: RTX 3050, Win 11
Action! Not Working!
Sat Jun 01, 2024 7:29 pm
Hello there. I bought the program through steam and have been using it comfortably for a long time. but for about 1 week the program just stays on the splash screen and only the mouse cursor rotates. I have uninstalled and reinstalled it many times, updated steam, then uninstalled and reinstalled it with “uninstall” programs, but it still stays on the same screen and does not open in any way.
As you can see, it stays on this screen even though the loading bar below is full. note: I also ran it as administrator, installed it on another drive, same...
Re: Action! Not Working!
Tue Jun 04, 2024 7:00 am
Please try following steps below to completely re-install Action.
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
6. Install Action! again.
