Rankor164
PC Specification: Ryzen 9 7950X, RX 7900 XTX, Win 10 Pro
Action! Doesnt find my active game Battlefield 2042
Thu Jun 06, 2024 7:11 am
Hello dear community,
I bought Action! yesterday to be able to take a few BF2042 shots. If I use the “Game” mode for recording, it does not recognize that Battlefield is started.
If I use the “Screen” mode, you can see in the preview how the game starts, as soon as the connection to the Battlefield server is established, the view changes to the desktop even if the game is in the foreground. What is inexplicable to me is that Action! recognizes my NZXT CAM as a game.
When I use the “Window” mode, Battlefield is not available for selection under “Selected application”. Even if I then switch to “Share display” and select the corresponding monitor on which Battlefield can be seen, only my desktop is recorded.
I have tested all hardware acceleration modes (AMD AMF HDR10, AMD AMF, AMD AMF HEVC, disabled).
I have tested it with and without time shift.
I have tested all possible modes even range mode.
I have tested video sizes (1080p, 1440p, ... Original).
OS: Windows 10 Pro (all Updates)
Video Card: AMD Radeon RX 7900 XTX Red Devil
Monitor: Gigabyte M32UC connected via Displayport (tested with and withoud active HDR)
Memory: 64 GB
Monitor Resolution: 3840x2160
Video Editor: -
Game Problem: Battlefield 2042
Video Type: MP4
Does anyone have any idea why this might be?
Kind regards
Johannes
Ryzen 9 7950X, RY 7900 XTX, Windows 10 Pro
waderatke
PC Specification: Windows X
Re: Action! Doesnt find my active game Battlefield 2042
Mon Jun 17, 2024 10:45 am
Disable Overlays: Some applications, such as Discord, NZXT CAM, and even Steam, use in-game overlays. These overlays may interfere with Action!'s recording capabilities. Try removing overlays in any apps that are running alongside Battlefield 2042.
Check the antivirus/firewall settings. Antivirus software and firewalls may occasionally disable screen recording applications. Check your antivirus/firewall settings to make sure Action! has the proper rights.
asciblewham
Tue Jul 30, 2024 1:39 am
Thanks for the tip. My Action! wasn't working and was blocked and I was literally scrambling for a solution for the past week.And as you said, it was blocked by my antivirus and I didn't notice it. Now my Action! is working fine. :D
polim
PC Specification: CPU Model: Intel Core i7-13700K
Fri Mar 07, 2025 2:32 am
This is an excellent and well-thought-out troubleshooting approach! Disabling overlays is a smart and proactive step, as many in-game overlays can cause conflicts with recording software like Action!, leading to performance issues or failed recordings. Identifying and disabling overlays from Discord, NZXT CAM, and Steam ensures a smoother, more stable recording experience in Battlefield 2042.
